PUCampin
Mar 06, 2014Explorer
SDcampowneroperator wrote:
If it is a leak on the tank, they are easy to weld.
X2 While replacing the control board on my atwood I accidently caused a leak by putting a screw into the tank. After taking it out and taking it completely apart I had a friend heli-arc weld it. He did it for free but a shop I called quoted me $25 for the simple hole. MUCH cheaper than $250 for a new unit!
The screws around the outside are what keeps the unit in place. Remove them and it will slide out. The water lines are probably long enough for it to slide out, the propane won't be, but I believe it unscrews at the front. It is probably doable to completely remove it from the external opening, but will be easier if you can get to the back.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
