Trackrig
Jan 05, 2015Explorer II
On our Splendid, in the rear passenger corner, there is a small wooden inspection cover than can be removed from under the front of the washer. It's about 7" square. After removing it you should see three hoses. Make sure your have antifreeze in all three of them. They should be a hot, cold and drain line. You'll need to pump the antifreeze into the washer to get it through the hot and cold line. Then poor a little more into the washer itself and run it until you know the drain line is full of antifreeze.
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
