mena661
Sep 27, 2013Explorer
BFL, I was second guessing for a bit but not anymore. I 'm not sure your thread can be used for my batts as the plates are thicker than yours. To add some info...I have 4 L16's, 370Ah each.
MEX wrote:This is the issue, the reason I'm asking is I want to run a combo MW/convection oven (~150A while running) for a good 20-25 minutes a pop. We don't use the MW portion. Probably once a day while camping. We're not full timers so it's just going to be for a 3-4 day weekend, once a month max. So that's why I'm concerned about voltage drop.
A longer run time would be umm not intelligent with batteries. My 2-volt cells can do it but it takes an F-650 stake truck to haul them.
L-16 batteries are built for 20 hour discharge rates not 5 hour or 5 minute.
12thgenusa wrote:I believe they are 1.17. There is a formula for calculating this and that's what I got for an answer.
Some 6-volt batteries have lower Peukert than some 12-volt batteries. Ballpark number that most articles refer to is 1.3 for deep cycle FLA. It can range from 1.1 to 1.5.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
