BFL13's avatar
BFL13
Explorer II
Sep 22, 2018
How Does a Converter Hold its Voltage?
A solar controller uses PWM but how does a typical RV converter do it? How much play is there up and down to hold it there?
I have a 12v mystery draw I am chasing down, but in the middle of this, I see the Trimetric often has negative amps showing (up to 2 amps it varies a lot over time), while the battery voltage is held ok at the setting (13.6 or whatever else)
If I raise the converter's adjustable voltage a tiny bit, the Tri shows charging again, but soon falls back to negative amps. Weird?
Is this an AGM thing? I always had a small positive amps with the Flooded batts and the Trimetric lamp was always showing a charge. AGMs have little self-discharge for the converter to overcome.
I am wondering if the converter is "cycling" a little so there can be times when no amps are going to the battery and you see some negative amps. (I do have a 12v draw of about 2.7 amps with the converter unplugged--But I think the converter should be covering that even if the batts don't want any amps. Another mystery.)
I have split the battery bank to see if it is a "bad" battery issue, but no difference.
Anyway, I am wondering about the converter's operating procedure just to know more about that, and AFAIK the mystery draw is a separate issue. Thanks
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 29, 2025
