Almot
Mar 06, 2016Explorer III
TUCQUALA wrote:
If the battery side + of a controller is interrupted by a bat cutoff switch between the controller and the battery, are there any major problems with such a setup when turning the cutoff on and off during normal use.
Flipping the cutoff on and off is not what II would call a "normal use". Normal wiring would be controller to battery via its own breaker. Not directly to battery, and not via general cutoff switch.
Same for loads - they should be connected to battery via "loads" breaker.
Then you can disconnect either loads or controller or both, if needed. Disconnecting loads is what you do in storage, - this is better than battery disconnect because you stop battery drain but keep controller running, maintaining the battery. Or flip controller breaker if you absolutely have to - and then it should be the FIRST thing to do.
In my trailer the only "battery disconnect" is a battery fuse, mounted on the battery Pos terminal. From there, Pos goes to Pos buss, and from there - to the aforesaid loads breaker and controller breaker. I bypassed the general trailer fuse under the frame - too darn inconvenient. Serious guys have a proper battery switch by Blue Sea, besides the battery fuse. I've been postponing this for years 'cause don't see what exactly it will give me.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
