brulaz
Mar 07, 2016Explorer
Almot wrote:sch911 wrote:
My solar controller is hooked directly to the battery posts.
It should be connected through its own breaker or fuse. Not directly.
That's what my controller recommends.
And the battery disconnect just turns off the loads (WFCO panel and so on).
But the controller recommends turning off the solar input before the battery breaker, so it has a chance to go into the "resting" stage and update its logs before it is turned off. Don't think there's a problem otherwise though. Other controllers will be different.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
