CA_Traveler
Apr 11, 2014Explorer III
path1 wrote:They work and I've used one. But after a while it occurred to me that they are more prone to road hazards. So I worked out an alternative.gbopp wrote:
Did you ever consider a Fumoto Oil Drain Valve?
They are great. I put one on after putting on new oil pan. Works great, all vehicles should come with them. Thought about putting one in the stripped out oil pan before changing, but wasn't sure at the time if it would work or not and didn't want to chance it. I have found out since then that is what I should of done.
Will you ever have a road failure with one? Probably not. I even put one on the gen and that was the one that broke. Fortunately I saw the oil and replaced it with the steel plug which is unlikely to ever become damaged.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
