path1
Apr 12, 2014Explorer
MEXICOWANDERER wrote:
NOT YOU!
I'm talking about the stripped drain plug. Ever watch a dummy "Lube Bay" employee at work, they TWIST the lube tip off the zerk when finishing shooting grease which loosens the zerk. At a Wal-Mart, I watched an idiot drain the oil from my car, change the filter, take a break and come back and start the car. Hell yes the engine clattered. He shut it off, then dashed and got the oil. I went into the men's room and guess what....the reek of marijuana.
Tip: Don't do your underhood inspections in the daylight. Do them at night with a strong flashlight. Your vision and brain will focus entirely on what the beam illuminates. The white LED lights are the best. In pitch black see if your engine's spark plug wires are sparking or giving off a blue yellow corona especially near the distributor cap.
I would not insult someone on this forum the way that your answer suggested my prior answer did. The indictment was and is against a work force that has degenerated in the last thirty years.
(didn't take it as insult). I don't take anything here as an insult on any forum to many varied positions on everything. Something as simple as getting a RV washed turned into fights sometimes. I was thinking out loud to myself how it came to be that grease will do wonders on digestive system. Somebody had to find out. Next thing will be a commercial on TV to join a class action suit if you've eaten grease.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
