BobsYourUncle's avatar
Feb 17, 2014
How easy to pull furnace fan out?
Today my furnace fan started screaming like a banshee on startup. It howls for a few seconds then quiets down.
I know I need to pull it apart and lube the bearings, if equipped, or otherwise effect a repair to it.
I'm amazed it lasted this long without groaning in protest at my over-use of it.
Anyhow, I need to pull the fan out and service the thing. I have never had one of these things apart before.
Anyone know if it has bearings or bushings?
Do I go at it from the inside or the outside? Do I have to pull the furnace out to do it? I haven't even looked at it yet aside from a sideways glance as I walked by on my way to the potty room.
I have good access to it from the top too, by removing a piece of plywood in the lower bunk to expose the furnace, HWT and water pump.
Maybe it just needs another pound of butter........
It is an Atwood Excalibur 8500-III hydro flame - 1997 model.
Thanks.
  • It is not at all hard- no need to remove the furnace at all. From the outside, remove the circuit board, black plastic fan shroud (remove fan relay to help), large squirrel cage (1/8" allen wrench), small squirrel cage (long 1/8" allen wrench through the hole in the cover), loosen bracket, pull motor (I leave the small squirrel cage in the housing and pull the motor out from it). Takes me around a half hour.
    The bearings are sleeve type, permanently lubed (!). If the shaft is wobbly (and has worn), you must replace it. If it is just dry, replacement is recommended, but I have drilled a small hole in the bell end to add oil. One time I installed a new motor, had it start to squeal after a single day, so I oiled the old one (customer was leaving for the summer before i could get a replacement). It lasted most of a year until they returned the following fall.
  • If you haven't done so already, try some creative ways to get some lube in there before you pull it out. I've used long tubes of the diameter of those on sewing machine oil (which works like a dream, BTW), specially bent lengths of coat hanger with q-tips taped to the ends and even a length of broom straw dipped in oil. This has given me years of extra service on fans from those that are seldom used to ones that work for hours a day.
  • All you have to do is follow the installation procedure in reverse. Not a smart a$$ answer, just what I read in an Atwood manual. If you do not have the installation manual, you can download it from Atwood. The odds are that it has bushings and while putting some oil on the bushings may help for awhile, you will need a new motor.
    The tech that replaced mine (a Suburban) said the worse part of the work is removing the squirrel cages from the motor shaft.
  • When mine sang to me it turned out to be the "squirrel cage" type thing (hamster wheel looking thing) had broke lose from the shaft.
    Sorry I can't answer your question as to how easy. RV was parked on lot and call RV guy to have fixed by following weekend. So it was pretty easy for me.
