JRRNeiklot
Oct 22, 2016Explorer
burningman wrote:
The bigger and shorter the cables, the better the inverter will work.
One good way to get enough current to the inverter is to double up on the cables. Use cable big enough to run the thing by itself, then double up and use two + and two - cables instead of one each. This is a case where the old hot rodder's axiom "too much is not enough and when in doubt, double it" is absolutely correct.
So, could I double this 1/0 cable I have? I have plenty of it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
