Ford v10 (v8,v6) when water temp reaches a certain temp, half of the cylinders shut down into limp. What is the actual temp in degrees that this occurs?
At those temps your flirting with warped heads and blown head gaskets. Don't be worried about limp mode, worry about keeping the temps down what ever you have to do. Sometimes you have to pull over and stop if you cannot keep temps in check.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
