Ford v10 (v8,v6) when water temp reaches a certain temp, half of the cylinders shut down into limp. What is the actual temp in degrees that this occurs?
If you find yourself in an overheat situation, you can buy yourself a little time by turning the cab heat on max and the fan on max. If your engine also heats the house, turn that fan on max also. Those heat exchangers act like tiny radiators and will dump some heat that can help you get to a shoulder or an exit to pull over. Of course you'll be uncomfortable for a bit. :)
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 21, 2026
