How can I check to see if voltage to pump is enough m..slide is very slow..mcant find a bind, has fluid, can't find any leaks 1997 Winnebago vectra , Chevy workhorse Thanks in advance
This White-Rogers 124-10511 is continuous duty 100A, the one I pictured above is continuous 80A.
Here's the Prestolite SAZ-4201ER1
Both "Four Terminal" with different mountings.
I got one like the Prestolite at the auto supply to repair a friend's hydraulic lift gate. Actually I think it was a Ford Starter Relay. Here's one for $13
