base1957ExplorerSep 17, 2017how hydraulic slideHow can I check to see if voltage to pump is enough m..slide is very slow..mcant find a bind, has fluid, can't find any leaks 1997 Winnebago vectra , Chevy workhorse Thanks in advance
wa8yxmExplorer IIISep 18, 2017One advantage of HYDRAULIC slides/jacks is you can use a smaller motor/pump and move more a lot more slide (or jack) very slowly. Just so you knowThis means lighter wire, less expense and less strain on the batteries. So there are very good reasons for doing this.Of coruse you can get there with gear reduction on mechanical slides too but hydraulics.. Way easier
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentAdding power outlets in slide with no wiringSuspect hydraulic pump (slides) fadingHydraulic slide problemHydraulic slide pumpHydraulic Slide Out issue
