How can I check to see if voltage to pump is enough m..slide is very slow..mcant find a bind, has fluid, can't find any leaks 1997 Winnebago vectra , Chevy workhorse Thanks in advance
Thanks Doug Jack's were were working fine. Slide use to work was fast out, slow in. Then got slower and slower coming in. Found post which hot wire from battery onto the solenoid was loose. I'm ordering the one called for by manual but I suspect I have other issues as the letter or leveling jack's worked fine.
