How can I check to see if voltage to pump is enough m..slide is very slow..mcant find a bind, has fluid, can't find any leaks 1997 Winnebago vectra , Chevy workhorse Thanks in advance
Jd that one has two cable posts. Mine has only one. I was excited when I first found those but they are not similar. I'm trying to. Find out if it would fit and how I would need to alter the connections. Possible that all I would have to do is drill a spot for a ground cable. I just don't know if that would have any affect on how it works. I dont see how it would.
