Gdetrailer
Jul 11, 2014Explorer III
Dick_B wrote:
The latest refers require a `comfortable' level ie. if it feels good to you then it's OK with the refrigerator.
That's "manufacturer speak" for we WILL get to sell you another fridge must faster..
Level IS LEVEL, not "comfort", just because YOU may feel "comfortable" doesn't mean it is good or BEST for the operation AND LIFE of the fridge.
Level is BUBBLE BETWEEN THE LINES.
Anything else WILL slow down the movement of the ammonia solution.
Anytime the ammonia solution is slowed down the BOILER GETS STARVED.
Anytime the boiler gets starved, it OVER HEATS.
Anytime the boiler overheats the ammonia solution CRYSTALLIZES.
Anytime the ammonia solution crystallizes you get blockage.
Anytime you get blockage it is PERMANENT.
On top of that is anytime the boiler overheats you get the potential of said boiler CRACKING.
Anytime the boiler cracks you have the potential for FIRE.
Dick, it isn't the manufacturers fridge once it is outside the warranty, it isn't your fridge either.. No, it is someone else's fridge and they will be the one that will have to make the decision to replace the fridge or rebuild it when the cooling unit fails.
These "newer" fridges DO NOT LAST AS LONG AS THE "OLDER" ones do, perhaps it has something to do with the "feels comfortable" statement?
OP, your fridge is telling you that it is not happy, LISTEN TO IT.
Level your trailer (use a 2x10 or two under the low side wheels) when you park it. Level out the tongue as best as possible.
Try to shoot for no more than half the level bubble outside the lines (less bubble outside is BETTER and fully within the lines IS BEST).
Otherwise don't bother precooling your fridge, instead start it when ready to pull out. As long as you put in precooled food and may be several bottles of FROZEN WATER (several 1/2 gallon or even a handful of 20 oz bottled water that has been frozen) in the fridge section it will cool down pretty fast and you will be good to go.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
