dougrainer
Jul 12, 2014Nomad
#1Flyboy wrote:
. . I guess I am lucky; I park on a nicely slanted spot for several days while preparing for trip & my Dometic, while plugged in, works great ( and will even freeze water in ice cube trays ). . .I keep the back, burner & vent clean tho. . .
It can take years of slightly off level to ruin a cooling unit. The cleanliness is not a factor on off level running. EACH time you run off level, you destroy a minuscule part of the cooling unit. Over time this adds up and then one day it does NOT perform to spec and you wonder why. Because you did NOT see any problems the few times you ran off level, you thought you got away with it. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
