Smitty77
May 13, 2018Explorer
Appreciate the group info sharing. Interesting the years of usage, some remove batteries for longer term non use, some use Battery Tenders.
And some also shared the actual chargers in their units. In hindsight, that would have been good info sharing. And of course, soo many variables, even it say three people were using the same Magnum MSxxxx - the devils of the details of how they're set up for hook up wise, as well as setup parameters - would be also needed to be meaningful for comparison.
Thanks for the info sharing, and best to all,
Smitty
Note: Magnum MS2812, now on Custom setting for Lifeline's newer slightly higher Float voltage. I'm currently using 4 hours to end the Absorb cycle. Also have a MidNite Classic 150 being fed by 1200W of solar. Same settings as the Magnum on voltages, but using Ending Amps appropriate for out House Bank Size to close down Absorb...
Smitty
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
