6string's avatar
6string
How long of a coax on carry out sat dish
Researching sat dishes winegard says 50 total and King says 75 total. Considering on my phaeton there is about 30 inside it doesn't leave much length outside. Help me out guys. How long of coax have you used with good signal?
  • I have a Tailgater (gen 1) with 100-ft + 50-ft. 100-ft works flawlessly, 100+50 works fine also but SOMETIMES requires 2 or 3 reboots to get all the sats. That said, 100+50 works so well that I am confident that 200-ft will work, as long as it is one run and there is no connector in the middle.
    I have a pass-trhough for the coax and no other junctions. IMO, the connectors add significant loss.
  • 15 years ago I had a customer with a 1994 Tiffin motorhome. He was upset because the CABLE input and cable thru out the RV was RG 59 instead of RG 6 and wanted Tiffin to replace all the coax with RG6 even tho he was out of warranty. I asked why it was important to have the RG 6. He stated that Direct TV told him his tripod mounted dish would NOT work with RG 59 coax cable and he stated since he could not get it to work then Direct was correct. Well, he did not understand HOW RV's run the coax input which is NOT a Sat input. I then charged him to rewire his Winegard booster to allow his Tripod to work. I then had him set up his tripod at the dealership and he locked into the 101 sat. I then connected a 250 foot box of RG 59 coax between his tripod and the input of his motorhome. With his coax the 250 foot and the 50 feet inside the RV we had at least 350 foot of RG 59 cable. He had flawless reception and when going to signal strength there was no difference between the 350 feet and the regular 100 feet of cable. That said, some Domes and such require a specific shielded Coax for best operation----King dome's are one, They supplied a special Coax double shielded cable for installation. So, use the shortest cable you can when installing and then after you verify reception, just plug in a 250 box of RG 6 cable and see if you loose reception. I doubt you will and you have proof that 300 foot of cable will work with your portable system. Doug
  • I have a 30' and 50', but can't even remember the last time I used the 50'. Whatever the length, buy good quad shielded RG6 cable for better signal.
  • I carry a 100-foot, a 50-foot, and a 30-foot coax. I have had to use all 180 feet more than once. The picture looked fine. (Digital signal is either fine or not there at all.)
    I use a Tailgater to get Dish Network.
  • I have 100 ft on a roll that I hook up at the trailer and roll out to where ever the tailgater needs to be. I leave a pigtail sticking out of the center so that I don't have to unroll the whole thing to connect the dish.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
