swimmer_spe
Mar 22, 2023Explorer
wa8yxm wrote:swimmer_spe wrote:
Typical code 24 battery, how long should it last with lights and electric RV fridge? I am only getting about 24 hours before it gets under 11.5V. Also, would a battery shop have a way to properly test the battery to see if it is actually any good? Would an RV shop be able to properly test it?
A group 24 is around 70-75 amp hours and you can only use about `15 of them before it is run down. So not long
A pair of GC-2 (6 volt golf car in series) are 220 give or take a bit amp hours and you can use half. that's a lot more than one G-24
Brand new trailer with a new battery. I'd rather not need to change the battery out for a weekend of boondocking for a weekend every now and then. If I were doing it once a month or more, then, I would see the need.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
