swimmer_spe
Mar 22, 2023Explorer
ewarnerusa wrote:swimmer_spe wrote:MNtundraRet wrote:
That's about right. You should not be running an electric fridge on that battery. The battery will be shot before the end of the year.
We have no choice as it is a 12v/120v fridge. I typically do not use it on 12v except for while driving.
If boondocking you'll have to run it on 12V, right? Is that how you're testing it during your 24hr test?
With a propane absorption fridge, a single group 24 would probably be be pretty low after a weekend of fridge and lights (also water pump and maybe fans). A 12V electric fridge would be a much larger load on the battery.
Last fall I turned the heat to room temperature and fridge on and in 24 hours, the battery dropped to around 11.5v. They don't install absorption fridges anymore.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
