pianotuna
Mar 24, 2023Nomad III
swimmer_spe wrote:ewarnerusa wrote:swimmer_spe wrote:
...They don't install absorption fridges anymore.
That's what I've gathered from the forums. Followed by grumpy scoffs from boondockers! LOL You mentioned that you're in a one-off boondock situation so not worth investing in any more gear. So you can fire up your tow vehicle and plug in the trailer via 7-pin to get some juice into the battery. Without upgrades to that wire path, it will not provide a whole lot of current for charging. But it is equipment you already have.
How long should I run it for if the battery goes down below 12V?
I do boondock with others, but they have a generator. That generator is not mine, and is not available for this one off time. I do plan to get a generator, but not likely for this trip.
12.3 volts is 50% If it is a marine battery that's already pushing it too low.
It would be pretty hard to say how long--but assuming an 80 amp-hour group 24, discharged to 12.3 (40 amp hours down), about 2 hours with #4 jumper cables.
The computer that controls charging "listens" to the starter battery. That tapers the voltage so that not much charging is done. A dc to DC charger would solve that. My dc to DC does about 17 amps at idle. It is rated for 20 amps.
Charging by idling the tow vehicle would be my last choice.
If the tow vehicle is diesel, make sure it is on high idle.
My first choice for a "one off" trip would be to use auxiliary battery to supplement the group 24.
Have fun on the trip.
