DrewE
Apr 25, 2018Explorer III
I suspect there was some load other than just the propane/co detector and radio memory. Those should not add up to more than a couple hundred milliamps or so, which works out to maybe five or six Ah per day. That certainly is enough to put a dent in a single battery, but should not be enough to make it completely flat assuming it was charged to begin with.
Was the breakaway switch for the brakes possibly turned on? A light left on somewhere that's not readily noticeable, like in a storage compartment perhaps? The TV antenna booster?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
