maillemaker
Apr 26, 2018Explorer
Why not just utilize the battery disconnect switch and kill all power from the battery. As it's been said there is always parasitic draws.
This is what I did. I went to Harbor Freight and got a pair of battery cut-off switches for the engine and house batteries. Whenever I park the RV I disconnect all the batteries.
The only problem with the Harbor Freight switches is the plastic knobs are not well molded to the brass part of the knob. So you twist the knob and it does not twist the brass part. I drilled through the whole assembly and pressed in a pin.
Steve
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
