time2roll
May 03, 2017Nomad
ricks99 wrote:No, actually much less than 5 weeks. Probably 100 to 500 milliamps or 5 to 15 amp/hrs drain per day. Battery holds maybe 90 of which you should only use 50 percent or 45. So you need to plug in every 3 to 9 days. Or disconnect a cable and you are good for 3 to 6 months. Even disconnected you need to start tip-top 100 percent charged.
Is it normal for a battery to last only 5 weeks when parked?
The 12 Volt Side of Life
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
