RoyB
May 03, 2017Explorer II
I completely disconnect my fully charged battery bank when parked here over the winter months... It starts out reading around 12.6-7VDC and usually only drops down to around 12.4-5VDC over NOV DEC and JAN...
During the winter months I can read my batteries with only my Battery monitor meter connected and I usually check on it ever two or three weeks...
Sometimes when it gets down to 12.5VDC I will hookup my trickle charge for a day or two... This next winter season I will have my 10WATT small solar panel hooked up all the time giving the batteries a slow continuous trickle charge.
If you let them set you have to pull one of the battery terminals otherwise the parasitic drains will run them down in just a week.. Its best to install a disconnect switch as removing and replacing the battery terminal may or may not keep you with a good solid connection depending how tightly you install the terminal each time...
Hopefully your batteries are not damaged. Once they go below 12.0VDC it is like driving a nail in their coffin... Do a slow long charge on them using a smart mode charging mode charger. Do it two or threes time in a roll...
Got to take care of the batteries as they are your lifeline for trailers.
AT least once a month when sitting here between trips I do a walk around and read the sitting battery voltage. I like to always read at least 12.5VDC or more. Then I switch in the batteries to the trailer and hook up to my garage receptacle which turns on the converter/charger unit and then I look at the battery terminals DC VOLTAGE again and I want to see it jump up to the 13.6VDC or higher depending what smart mode the charger jumps up to. If I don't see the DC VOLTAGE jump up then that tells me my Battery charging system is not working...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
