BFL13
Oct 12, 2017Explorer II
time2roll wrote:
Guess? 15 amps x 6 hours = 75 amp hours. So you need 150 amp hours minimum. So 3 batteries should be enough. I throw in one more for good measure and unknown conditions.
Or bring the Honda.
Yes, but people seem to be assuming the battery will run down to 50% before the inverter shuts down, when I am wondering if the inverter will shut down right off because the inverter-battery wiring is not good enough. Or it might shut down real soon after it does run for a short time.
I am questioning how people can be assuming that without knowing the actual wiring.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
