time2roll
Oct 12, 2017Nomad
BFL13 wrote:I try to assume OP can follow the install instructions. Or he can ask.time2roll wrote:
Guess? 15 amps x 6 hours = 75 amp hours. So you need 150 amp hours minimum. So 3 batteries should be enough. I throw in one more for good measure and unknown conditions.
Or bring the Honda.
Yes, but people seem to be assuming the battery will run down to 50% before the inverter shuts down, when I am wondering if the inverter will shut down right off because the inverter-battery wiring is not good enough. Or it might shut down real soon after it does run for a short time.
I am questioning how people can be assuming that without knowing the actual wiring.
Part of the reason I throw in one more for unknown conditions.
Also good chance the batteries show up only 85 percent charged.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
