theoldwizard1
Oct 17, 2018Explorer II
Ed_Gee wrote:
Rule of thumb: for 100W AC , the 12VDC current out of your battery would be ~ 10 Amps, so your 200W load would be drawing about 20 Amps from the battery. That gives you about 2 1/2 hours to reach the battery capacity half point where you should stop. If you run your battery down to 10.5 VDC more than once or twice you most certainly kill your battery.
pianotuna wrote:
About 1.34 hours to 50%. Discharge is not linear.
So 1.5 - 2.5 hours is a reasonable range.
I would go for the low number.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
