BFL13
Oct 17, 2018Explorer II
pianotuna wrote:
Hi,
About 1.34 hours to 50%. Discharge is not linear.tealboy wrote:
connected to a 100 amp hour deep cycle battery with a 200 watt continuous load.
Is the math 200/10=20 amps which means 2.5 hours run time before reaching 50 percent and shutting down or can I get a decent amount more run time!
The SG and voltage per SOC during discharging is fairly linear especially for the top 50%. Recharging is different with SG lag and the voltage jump past 80%
OTOH, when the draw is by inverter, a steady inverter load will have the amps draw rising as voltage goes down to try to maintain the watts. So in that case it would not be so linear.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
