time2roll
Oct 17, 2018Nomad
allen8106 wrote:I believe that is resting. BCI reserve capacity (RC) is 25 amp draw to 10.5 volts and I believe this is the common voltage under load to designate 100% discharged.
Batteries are considered discharged at 11.6 volts. If you are taking them down to 10 you are damaging them.
Mostly semantics. Ether 11.6 or 10.5 is too low to get decent life out of a battery.
Now that I think about RC rating in minutes.... OP could probably use that as a guide as the draw is similar. Just cut the RC minutes in half to get to 50%. Trojan group 27 has 175 minutes so 1.5 hours could be real close.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
