tealboy's avatar
tealboy
How long will this battery last using inverter?
Ordered a new inverter, Wagan smart ac400,sells for appx $40 and is modified sine w .6 amp draw no load, rated 90 percent efficiency, full time fan and is said to run a true 400 Watts 24 hrs w surge to 1000.
If connected to a 100 amp hour deep cycle battery with a 200 watt continuous load, how long will the battery hold up before it hits the 10-10.5 volt and the inverter shuts off?
What is worst case and most likely scenario using a relatively new battery? Thx.
Is the math 200/10=20 amps which means 2.5 hours run time before reaching 50 percent and shutting down or can I get a decent amount more run time!
  • Going to be less than 2.5 because you are discharging at the 5 hour rate not the 20 hour rate. Faster the draw the less energy you get. Wiki Peukert for more information.
    More like 1.5 to 2 hours max to 50% level.
    Unless it is a Lithium battery then you have minimal to no Peukert effect and you can run it down 80%.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 26, 2025
