Ok so I picked up 4 Trojan T-105s today, the battery boxes showed and I should have the 75amp Powermax charger tomorrow. I am planning on two banks each with a battery switch and then to a 650amp buss bar, the Powermax will connect to the buss bar. I am getting a 2000watt PSW inverter that will Also connect to the bus bar, should the inverter be fused?
I am also installing a lift gate plug for connecting to a truck campers batteries, I was planning on a 120 amp breaker on this Incase of issues with the umbilical or the truck camper. Eventually I will be installing a charge line from the truck, this I was planning on a 120amp breaker as well on each end.
