- slowlyiturnExplorerno solar, yes charging batteries.
- mcheroExplorer
slowlyiturn wrote:
dry camping in mexico for the last 2 years with this Honda 2000...560 hours. run it about 4-5 hours per day
You using it to charge up your batteries? You using any solar? - slowlyiturnExplorerdry camping in mexico for the last 2 years with this Honda 2000...560 hours. run it about 4-5 hours per day
- mcheroExplorerInteresting link Snowman! Thanks!
- Snowman9000ExplorerThere is a way to read the hours via the number of times a light flashes after startup. I only bothered to do it once, so I've forgotten the exact instructions.
EDIT: googled it...
http://www.ar15.com/forums/t_10_17/649696_Honda_EU2000i_Hour_Meter_Info.html - mikestockExplorerI bought my EU3000is new in 2001 and used it for an average of 6 weekends per year for football tailgating. For me, being retired, these weekends are usually 48 hours minimum and living in Alabama it means air conditioning (15k) most of the time. In addition, I have probably used it for 1000 or more hours during power failures at my home. All together I would expect that my usage is 4000 hrs. or more, during the 12 years I have owned it.
I did my first valve adjustment a couple of months back and found they were still within specs before adjustment.
I change my oil frequently and always use Mobile 1 synthetic oil. - MEXICOWANDERERExplorerThe Yamaha 5500 ESD recommended oil and filter changes after 100 hours of operation. A diesel. An oil change and filter every four days.
- HuntindogExplorerNo hour meter on mine, so no precise figure, but several thousand hours is a realistic guess. I have the extended run tank, and it uses so little fuel that it rarely gets shut off.
A while back there was a guy here that said he had over 15000 hours on his... Smoked but still ran. - AtleeExplorer IIYou change oil after 20-45 hours?
whs9841 wrote:
I use my EU2000i pair for tailgating, so they get used anywhere from 20-45 hrs per weekend (depending on the weather). 6-7 home games a yr for the last 7 yrs., so I probably have around 1200 hrs on them. I change the oil after every tailgating weekend, and I clean the air filter every year. The only other maintenance I've done is replacing the spark plugs, cleaning the spark arrestor (only twice), and replacing one pull cord. I also start them up periodically in the off season to keep everything lubed up well. I don't see any reason why these things won't run another 6-7 yrs, if not longer. - randy328ExplorerMotorcycle racing, so runs quite a bit at a race. Friday through Sunday many times. I log the hours, rounded off for posting here.
eu2000 2450 hrs
eu3000 1100 hrs
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
