Gdetrailer
Feb 18, 2015Explorer III
zackyboy3rs wrote:
2 250 watt heat lamp bulbs? 5.5-6 gallon gas tank. I am thinking 12 hours.
500 watt is no real "load" for a 7Kw gen..
Typically the run time is given for HALF LOAD which will be the size of your tank.. You will be less than half load so I would guess you can use the half load number..
That is a awful big gen for that small load.. I would suggest finding a smaller gen that would match better and save on a lot of fuel.. A 2Kw gen would easily use 1/4 of the fuel..
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
