ChooChooMan74
Jun 18, 2016Explorer
I put it on the 5th on mine. Make sure you adjust the cams so that they both are centered when straight.
bandit86 wrote:That is false. You will have sag. The WDH helps put weight back on the front axle. It may also take some sag away.
I was in Genral trailers in Michigan picking up a trailer with my friend, the guy setting it up said the back should be just as high with the trailer loaded and weight distributing properly set up as without.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
