vermilye
Aug 18, 2013Explorer II
A 50 watt panel will not do much more than keep your batteries up when you are not using them. While a 95 watt panel in full sun will keep up with my usage in a small 17' trailer with LED lighting & the usual loads (including making a pot of drip coffee each morning), most systems start out at a couple of hundred watts.
To determine how much solar you need, you should do a usage survey. Keep track of how many 12V amp/hours you use over a typical day for a week or so. The average daily usage is what you are going to have to replace if you want to depend solely on solar. Since the panel(s) will rarely put out their rated wattage, and you will have cloudy days, and of course, dark nights, you will need more solar wattage than your average use. You will also need enough battery to cover the times your solar system is not meeting your demand.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
