TomG2
Aug 18, 2013Explorer
If you want to gain a couple of days boondocking, you do not need enough to power your rig every day for a month. You say you are getting two days now, and I suspect that a 50 watt setup would double that, since you will be charging for four days to gain the two. The experts can tell you how many Ampere Hours per day that a fifty watt setup will provide.
If your idea is to never run your generator and use even more electricity than you currently are, then you will need the suggested systems.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
