Bobbo
Nov 13, 2018Explorer III
LittleBill wrote:Bobbo wrote:BFL13 wrote:
Not answered by the OP is the post in another thread where he said he can't get through one night with his current battery bank with the furnace running at a decent temperature, so they freeze under many blankets. the usual rule is one night per battery and he has two.
So that must mean his batteries are already shot, and need replacing now unless he is not going off grid for a while.
Sigh. You are fixated on my batteries. I am not focusing right now on my batteries. I am focusing on whether I should go to the trouble of pulling out my 45 amp charger and replacing it with a 55 amp charger. Will the answer to that question change depending on whether the batteries are good or not? I have not answered about the batteries until now because that is not my focus. I will not answer about my batteries again after this. If and when I become concerned about my batteries, I will do something about them. I don't know about your furnace fan, but my furnace fan, running all night, tends to take a lot of battery power. With only 158 a-h of battery power, it isn't hard to run them down to 50% SOC on a very cold night with the furnace running non-stop. We have found a solution that works for us.NinerBikes wrote:
My solution... find another heater, that doesn't require electricity and your batteries all night.... there is stuff out there that runs on propane and a cracked vent and a cracked window for proper ventilation.
Olympic Wave 3 or Wave 6.
Please note that this thread is not about discharging my batteries. This thread is not about heating my RV. This thread is only about whether I would gain enough in recharging discharged batteries to justify replacing a 45 amp charger with a 55 amp charger. The way the batteries get discharged is immaterial.
unless you need every second of generator time to get charged back up before running out of time, and your wiring supports the 55amp model.
there is nothing gained other then time, and even then it will be a small amount. you have to decide if the time savings is worth it to you, that's about all your gonna gain, in bulk mode
Thank you. The answer I was looking for has now been provided. The time savings is probably less than 1/2 hour run time over a 4 hour +/- recharge time. That is not significant to me. I will leave the 45 amp alone, and if/when I do replace the batteries, I will stay at or below 225 a-h. That won't be hard because I only have room for 2 batteries and would have trouble getting more power out of just 2 batteries.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
