MEXICOWANDERER
Nov 13, 2018Explorer
BFL13 the only way to get an answer comparing full saturated charging and a maniac depressive converter, is to directly compare them both. I save well over an hour 50% - 100% I do not have the open ground nor money for 100 amperes @ 28 volts for panels. And my batteries are unforgiving of 40-90 constantly. Tropic blend electrolyte.
Bobbo you can save your money for a bigger bank and more generator run time. The difference in amperage and time would be negligible. Maybe save 15 minutes 50-100%.
I invite anyone anywhere to 50-100% charge (using specific gravity as the guide) a battery rated double in amp hours vs INITIAL charger output fixed voltage set at 14.8 versus 14.4 wimping down to 13.6 volts automatically.
Use a CLOCK. Use a hydrometer then tell me the difference in minutes between the two charging sources. No handheld wizards dongles or other paraphernalia. Just a simple converter like the OP uses. Versus a constant voltage charger source set at 14.8 volts.
Again! The battery cannot be more than 85 ampere hours to get a true and accurate reflection of saturated voltage regulated charging. The 400 watt Meanwell or Megawatt will do fine. Remember! Fixed voltage.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
