MEXICOWANDERER
Nov 14, 2018Explorer
NOW THAT
Senor bobbo will work. Use the generator and charger until charge rate sags 20% for a 45 amp charger, this means when the charger drops to 36 amperes, shut off the generator then let the panels have time that's the secret giving the batteries enough time to climb into the 85% + charged range power by solar panel. When amps are low because voltage is high the realm of the solar panel becomes king.
My problem is "low" means 100 amperes at 29.6 volts. Float on my system is 20+ amperes with no loads. Champagne lifestyle Ripple Budget.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
