Bobbo's avatar
Bobbo
Explorer III
Nov 08, 2018
How much converter/charger is really needed?
I have a pair of NAPA 9824M Marine/RV batteries with a 20 hr rating of 79AH each, wired in parallel.
Is there, really, any advantage in going from a 45 amp (PD4645V) converter/charger to a 55 amp (PD4655V) converter/charger?
I know that bigger is ALWAYS better, and the cost is not much more, but, really, is there a real advantage?
If not, how many AH do you need to make the jump from 45 amps to 55 amps useful?
  • Do you expect a fast charge from a generator? For the few $$ more get the 55.
    Even for a fast charge into a wet cell battery 20 amps per battery is fine.
    Mostly plugged in? 35 amp is more than enough.
    Usually the house load is under 5 amps so forget that unless you have multiple tank heaters etc camped well below freezing.
  • Bigger is not always better, bigger could be less efficient and waste more power. Converters/Inverters are not very efficient in the first place that's why they have those big fins to bleed off the waste heat.
  • Once the battery charging enters the absorption phase they won't accept big numbers. Charge with solar and you can "forget" all this anyway.
  • You could charge, theoretically, those 2 drained to 50% in under 2 hours...bulk. I see no advantage.
