John___Angela
Sep 11, 2013Explorer
westend wrote:John & Angela wrote:Do the LED bulbs you used have a regulator on them? Some of the "quality" bulbs from stateside sellers have a small regulation board attached. This may draw off a bit of current and that may explain some of the disparity between different user's reports on current drawn.
We did a little testing as well. After all is said and done using quality 27 Led single contact bulbs, we found we draw about 1/3 to a 1/4 of the power getting about the same amount of light. No where near the claimed 80 percent less power but substantial enough to justify the change.
Yes and as a result they also produce a little more heat. But they work well and have good colour temperature. We use outside lights a lot and also tend to leave a few lights on inside so they are on when we walk in (switch position etc). We don't worry about it as much as when we used the incandescents. Probably a little wasteful but its how we role. The energy we save negates the need for another solar panel. :)
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
