Sam_Spade
Jul 14, 2016Explorer
path1 wrote:
Bought new batteries. Before I install them and I need to confirm which cable is pos and neg.
A wise person would have done that before he removed the OLD batteries. ;)
At this point, the voltage is insignificant without the batteries in place. A very high reading is expected with no batteries in place.
Charge the new batteries fully BEFORE CONNECTING.
Then check the voltage before connecting, after connecting and with the converter active.
P.S. except for being sure it points to 0 when off, you do not calibrate the voltage scales of a multi-meter. And if it's digital, you don't "calibrate" anything.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
