mkirsch
Jul 15, 2016Nomad II
On this other converter you measured, did you disconnect the battery first?
Simpler converters use the battery as the voltage regulator in the system, and when disconnected from the battery, will put out what seems to be an excessively high voltage. Connect it to the battery, and the converter will "calm down" to a more reasonable output.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
