path1
Jul 15, 2016Explorer
OP here.....I have to do some more touch up of paint, to anxious I guess. (Thought paint was dry enough).
OK...here's what it is. Looks good to me.
13.45 on 120 a/c
13.76 with engine running (Alt charge line)
13.20 with generator running
Thank you everybody.
The link that Old Biscuit posted is very worth while if you have Parallax-electronic series 7300. I saved a copy on computer and printed out a copy for "my" RV's owners manual. Couple big clues to me were that several suggested in their posting, no big deal about higher voltage.
And Note 2 of the link said: "If the unit has correct DC voltage with “polarity” fuses removed, but does not when “polarity” fuses are in place the converter may be in over current mode. There may be a problem with either the battery, battery wiring, or a connected load. Remove battery (positive) connection at the “C” terminal or one DC load fuse at a time to determine where the problem is. Over current mode is the condition where there is a load(s) connected to the converter that exceeds the current rating of the converter. This can either be a “short” in the coach wiring or just too many things on. The output voltage will decrease as the current exceeds the rating of the converter."
This converter in question is in our x-rental Cruise America and pretty old (2001). We've had a ton of fun over the years with it. Good for shorter trips around the NW. Longer trips...wife has me convinced she could persuade a jury, that it was justifiable homicide when snowbirding in a 23 feet rv with no slides:). The other RV is her Arctic Fox trailer with the Power Dynamtics 9200. If I ever have to upgrade I'll probably will go with the PD. Lots of postings on here about how good of product and service they have.
Thanks again. This has been about the 3rd or 4th thing that you kind folks have helped me out on.
13.45 on 120 a/c
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
