westend
Jul 16, 2016Explorer
All the measurements you take won't verify that your converter is going to charge your new batteries correctly. The Parallax is a single voltage power supply and will never deliver enough current to keep your batteries healthy. If you plan to add solar charging, then keeping the converter original makes marginal sense. If you rely on it to charge your batteries with a genset, it is the wrong tool for the job.
I think you know what the solution is to the issues with your converter.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
