path1
Jul 16, 2016Explorer
path1 wrote:
OK...here's what it is. Looks good to me.
13.45 on 120 a/c
13.76 with engine running (Alt charge line)
13.20 with generator running
OP here...This thing is getting interesting. In the beginning of this thread I just wanted to make sure I got pos and neg hooked up right.
I re-checked the readings and there are about the same (see readings in quote above). But one thing I didn't check that I did checked this time was using in self contain mode. (Just running off the batteries)I went to that mode and nothing works.
Link has a pic...I'm not getting anything with volt meter between "C" and "D" which is pos and neg but only when using ON self contain mode. When hooked up to something I get 13.60
I don't understand how a battery sitting for 7 months with a small drain on it can mess up the wiring. I do see how running out the batteries it would mess up the wiring. It's not like gas going bad or tires rotting in the sun.
http://d163axztg8am2h.cloudfront.net/static/doc/e9/67/35ce35e99a07df33a431fcd8a86a.pdf
OK, that's where I'm at right now. Going to pick my tools up and move to another project, let this one rest for awhile.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
