westend
Jul 16, 2016Explorer
.I'm not getting anything with volt meter between "C" and "D" which is pos and neg but only when using ON self contain modeI'm going to assume that you have new batteries connected. Further assuming you have the polarity correct at the battery. Furthest assumption is that you have the voltages stated at the C-D points when converter is powered. Have you checked the inline circuit breaker or fuse close to the batteries? This should be in the (+) phase cable and may be near the battery or adjacent to a disconnect switch.
What is the voltage across the battery terminals?
You may also have a loose or corroded connection in the mix.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
